Samsung S10e Replacement Recommendations
kmonroe99
Looking for recommendations for a replacement for a Samsung S10e. The most important factor is size - this is for a person with severe rheumatoid arthritis and limited hand mobility. The S10e form factor of 5.6" x 2.8" is good. An old S6 form factor of 5.65" x 2.78" worked well also.
Replacement does not have to be Samsung and does not have to be 5G; wireless charging is desired.
Suggestions?
Thanks
what's your price range? what do you plan on doing with the phone? streaming? playing games? or just normal phone use (phone calls, text, and emails)?
what about the s9? or s20?
The Pixel 5 fits those size constraints and has wireless charging.
If a taller phone of the same width is acceptable then the Galaxy S20 and S21 become candidates (both around 6" in height but 2.8" or less in width). If you give up wireless charging then you get many more options.
GSMArena have a phone finder tool that lets you specify things like this and search for phones meeting your requirements. Since it's not an American site you have to use mm for the height and width, but that's a simple conversion.
