samsung S2
  • Start date Start date
A
Android Question
Guest
I can not connect my phone to my laptop as a USB when i connect it as only charger
With the S2, you have to manually select to connect the device as a "Mass Storage Device".
Pull down your status bar and you should see an option that says "connect as mass storage" when the device is connected with the USB cable.
Please consider joining our community and post back to this thread to let us know if that worked for you. Otherwise, we'll keep working with you to figure it out.
Welcome to AF!
