S3 Frontiers factory silicone watchband
My rash has only occurred in the past week after having it a year or so.
It is about the size of a quarter at most and is at the side of my wrist which is inline with my thumb.
I found that there is an imprint (raised) that looks like/says:
L
Gear S3
Because it is raised it is not smooth as the rest of the band is.
Has anyone else received rashes in the same location and what resolution or model band did you replace with?
Since it is silicone I am wondering the best option to try and smooth it over best as can without cause more (or other) damage.
Thanks
L
Gear S3
Thanks
