Samsung S5670 applications not geting downloaded
Hi ...
I am using Samsung galaxy S5670. I can access my mail, face book, maps etc from it by connecting to a wirelss net work available in my place. Android market also getting connected. After searching my favorite applications I clicked the option download, and it showed starting to download. But it never got downloaded. It is happening with the applications which are in the size of 110 KB. When I logged in to the net form my pc with my google id, android market allowed me to select the applications and to download it. It showed that the applications will get loaded in to mobile soon. When I tried to check the application from my phone, it is showing the names of selected applications , but when I am clicking on it , it is going to the same problem as I mentioned above . Please help me out..
Is that possible to down load applications as a file then install in the phone as we do with the other soft wares?
Thanks on advance.....
Welcome to the Android Forums!
Try rebooting your phone. Sometimes app downloads will get hung up and rebooting can potentially clear that.
I tried rebooting, it was not helpful.
I tried to download applications from "android zoom" . It sent me a mail with a download link. When I clicked that from my mobile it again redirected to the android market. Which was followed by the same series of events. Atlast I was not able to download the application. I tried to switch over to the flight mode before downloading(suggested by some one) . That attempt was also futile. Android zoom asked me to,scan a code using QR reader, since i dont have any application in my phone it was not possible.
Waiting for ur suggestions...
I am also having the same kind of problem. My os is Froyo (Android 2.2)
I was able to install applications from android market. But the softwares are not visible in Menu.
I checked the application status using Settings > Applications > Manage applications.
The applications are active there.
Any setup needed to make the apps visible in Menu?
Note: I was not able to open the applications even through open option available in markets. The open button is disabled but uninstall button is active
