Help Samsung S6 problem.
mickeyelk
Need some help. First time user of this forum so glad to see it exits and with so many people participating. The problem I have is: Plugged it in to recharge the unit. After taking it off the charger it would not come on. Press the power button and it will start to boot up but stops right after the Verizon red picture and then shuts down immediately. When replugged in for charging it show just the battey amount charge . From here hold the power button for a few seconds and it comes on as normal . Unplug it and it will not come on just shuts down. Is there a problem with this unit? When plugged in the unit works perfectly.
I think you are going to need to return that device. Not a lot you can do since the unit is sealed
Welcome to Android Forums!
Sorry you had to find us under the circumstances, but @chanchan05 is correct, that's either a bad battery or the circuitry that reads the battery. That's definitely something that needs to be addressed under warranty.
It seems that the battery has been completely discharged and it has some difficulty to wake up itself.
Shutdown your phone completely and wait until the charger is cold, plug it in the phone and wait, touch the charger with your fingers from time to time to see if it's hot, if the charger remains cold then the battery or worse, the charging circuit is faulty.
I've tried all the above thanks allot I'll take it back tomorrow to Verizon.
