Samsung straosphere wont charge
Have you tried a different charger or using the usb cable/charger to an ac outlet instead of the pc or visa versa? Look inside the male end of the usb cable and make certain none of the pins are bent over. Try pulling the battery out and put it back in making certain the contacts are clean. That's the most common fixes. If the phone simply refuses to charge it's likely a battery problem. Replacements are cheap but not readily available on Easter Sunday evening :( I hope something above helps.
You might also check into the Stratosphere area to see if the users in there might have some better or different suggestions. Here is a link to that area.
Samsung Stratosphere - Android Forums
