samsung unlock
Do you know the password ?? if yes, then it should be simple, go into your settings and go to security, and all your options should be there.
please i need help on how to remove password on samsung galaxy tab screen. from Hope
Welcome to the forums hopijar!
Fortunately enough Don has got you headed in the right direction. If you do not know the password however, you may be forced to factory reset your device in other words, lose all your data :(
If you need any more help feel free to ask :D
