Just made the mistake of reading the Quick Start pamphlet for the Samsung Wireless Charger.
It states...."When the mobile device is fully charged, disconnect the travel adapter from the wireless charger."
Duh? Does that mean you should NOT leave the wireless charger plugged in when not in use? If you have to plug it in each time you want to use it...it is just as easy not to use the thing in the first place! Just plug in your phone!!
