Help san francisco
makarov
um i just got this new phone the orange san francisco 1 i downloaded nyancatt to my music section from computer to phone but how i set it to ring tone please help fast.
Make a new set of folders on your SD card: The first one should be called 'media', then inside that folder, create 'ringtones' and put the file there. (It should be either MP3 or OGG file formats, I think M4A is also accepted, but not sure) Then the ringtone should show up in your ringtone list. Make sure you unattach your USB cable after doing this. The file will also not work if you are in USB disk mode.
If that doesn't work, download ES File Explorer, (https://market.android.com/details?id=com.estrongs.android.pop), find the file on your SD card, open it with the ES Media player, push the little bell in the upper right and "set as ringtone".
