SanDisk 64GB micro SD problems
rfortson
Member
Just a note to say that I put a SanDisk 64GB micro SD card in my LG Nitro and it's working fine. I want to carry all my music, and it wouldn't fit on a 32GB card, so I tried the 64GB based on reports that it worked on the Galaxy S3. Works fine once you format it in the phone.
EDIT - UPDATE
Well, after a few weeks I started having problems with card. Random messages started popping up saying the card had been unexpectedly removed. Other times files would show as corrupted and later would be fine. So I guess I'll have to change my report.
