D
Deleted User
Guest
My satnav finally died and I've decided to use my phone. Is it possible to use the navigation app offline or do I need to use my 3g.
There is a free one called OsmAnd & you can download the maps to the sd card for various countries, there is even a low level world map too.
I have also found it to be very accurate & it also has voice navigation too.
i just got that one and it looks promising. the one bummer is i can't find how to just manually add an address to navigate too, without having to go find the spot on the map.
