Save MMS to sd card
thaKing
I use Go SMS Pro and I'm pretty sure (unless I'm going crazy, and that's very possible) that I used to be able to open a MMS and save the pic to my external sd card. Now when I open the pic and hit Save, it saves it to my phone. Am I missing a setting somewhere?
If you can't set this on the settings of your MMS app you might try 'Save MMS', free in Play Store.
The app let you choose the place where you want to save your MMS pics.
Harry
Harry
Honestly, I thought I had this set to save to sd card in the past. I've recently flashed a new ROM and I can't seem to find the option within Go SMS Pro.
I also us Go SMS Pro, when you save a picture from the MMS or EMail they are all save to the default Download folder on the internal SD. Has always been this way.
Well, I *did* make the note that I might possibly be going crazy. :D Thanks for clarifying that...I dunno why I thought I had saved it to my external SD.
