Root Saving build.prop
urobolus
Anyway, I am rooted my Samsung Admire last night using the steps seen here because I want to run Order & Chaos Online on my phone. When I install it currently, it says it is incompatible with my phone, so I want to update the build.prop so it thinks it is a phone that it can run on.
I've verified the phone is rooted and that I have the right permissions to edit build.prop. I am using the free Root Browser, as opposed to the 3.99 Root Explorer. I make the necessary changes n the build.prop file, save and get a message about how 'Root Browser has a access to poweruser.apk', and then I get a message saying 'build.prop Original saved as build.prop.bak'. I double check the build.prop and all my changes have been reverted back to the old ones. Same happens when restarting. How do I fix this?
Thanks,
Uro
