Hi i bought the viewpad 10e for my daughter to do homework etc. but i dont know how to save stuff onto the sd card so i can put it in the printer, can anyone help? her email and dropbox dont seem to want to connect!! thanks
I am not sure what you are trying to save but by default most things should save to the SD card. You should be able to connect the tablet to a computer via USB and use the file explorer on the CPU to browse the files on the SD.
