Help Saving files to Samsung Note 10.1 or SD card
Cymraeg
Hi
I am in my late 60's and am not brilliant with my PC. I've now bought a Samsung Note 10.1 and installed an SD card. On my PC, if I want to save a webpage I just go to File: Save and then get the options on where to save. I cannot seem to fins any option on my Notebook for saving. Is this possible? Also is there a similar option to save photos directly to the SD card?
Sorry if this is all obvious to the more experienced ones of you.
Thanks
John
If you want to use external sd card to save stuff from internet, you need to change settings from a browser:
1. open the stock web browser
2. from the upper right corner, click the menu button then settings
3. click the sectionmaybe called something like "advanced settings" in english
4. There is section where you can change the "default saving place" between internal or external sd card.
When you want to save the webpage, click that menu button and select "save for offline..." and if you want to save files/photos, just tap the screen long with your finger on the photo and then you can choose "save..."
