Thanks for the suggestion - I'm a bit surprised that since the tablet came with the SD CARD already installed, that the tablet does not recognise the card?The_Chisuggestion post: 7165905 said:Have you tried a file explorer app to make sure your Galaxy Tab is seeing the SD card? You can also use an app called SD Insight to make sure the card is legit.
Are you sure it's preinstalled? Pop open the SD card port and see if there's a card inside. You might be referring to internal sd which is how older Android versions referred to internal memoryThanks for the suggestion - I'm a bit surprised that since the tablet came with the SD CARD already installed, that the tablet does not recognise the card?
Good point. I forgot that really annoying aspect. At one time a file manager would show a phone's internal storage as 'sdcard' and a removable microSD card as 'extsdcard'.Are you sure it's preinstalled? Pop open the SD card port and see if there's a card inside. You might be referring to internal sd which is how older Android versions referred to internal memory
