Saving/using images from web
dolbydan
Hi all,
Great phone and apart from the speakers a big step up from my existing Nokia 5800.
Big thank you to the members involved with the guides from the stickies!
The only problem I can't workout or find a solution from searching the threads is how to copy pictures/images from the web (on my desire) to use as, say, a wallpaper.
For instance I have pics on Picasa web albums, which I want on my phone.
Thanks Dan
Hi all,
Thanks Dan
All you need to do is press down on the image and an options menu will appear. You can then save the image if you want to :)
All that comes up is a wikipedia magnifying glass menu?
Thanks though :-)
Thats strange, when I hold down on a picture it gives me numerous options:confused: I know a couple of mates and they get the same options as me ? Perhaps the sites you want to copy the pictures from have them protected in some way ?
