roach48 Lurker Feb 20, 2012 #1 tHIS IS WHAT IT SAYS AT THE MOTOROLA SITE,DO i HAVE TO BUY MY OWN SD CARD Insert your microSD card Remove the microSD Card Slot tray located on the back of the device. Remove dummy microSD Card and insert your microSD card in the same slot. Insert the microSD card slot tray.
M marctronixx Moderator Feb 20, 2012 #2 yes you do. the tab comes with onboard memory and you can also add memory.
