bigshotproducer
Anyone having issue with battery draining like crazy? Looks like the phone won't sleep.....ugh.
Why not upgrade to SC2.6? My battery life improved slightly. Also check your time without signal, Settings>About Phone>Battery Use. If this number is high that is most likely your cause. One thing that helps is to place the phone in airplane mode, reboot, and let the phone sit in airplane mode for a few minutes. Don't know what it does but it helps lower time without signal,
Make sure the phone is un-plugged. Also on SC 2.6 if you freeze the Today Briefing, and Today Schedule Widgets this will help with battery life.I don't see anything says time without signal in there.
I am now on 2.6 with the EB16 kernel and my battery sucks big time! I just came from SC2.0 with the stock kernel and my battery was way better. I think I'm going to try and go back to the stock and see what happens.
Is cell standby there? If so that is it.It is unplugged
