Scaled down touchwiz??
krs128
How much has TouchWiz actually been scaled down?? I used a S3 before and absolutely hated touch wiz and it isn't much better on the Note 4 from what I have seen. Friends tell me that Samsung has really toned down their TouchWiz this time though.
Told myself I'd never get a non Nexus phone but Since the Nexus 6 is way to large and switching back to Verizon from prepaid AT&T (more data, slightly cheaper, better coverage), looking at the S6 since the camera on it is getting such crazy good reviews, and the battery life appears to be much better than the m9 (which looks to be a letdown) despite the better screen and smaller battery size.
with the scaled down TouchWiz, and assuming I load the Google Now launcher, and other Google apps like the keyboard, messenger app. How much can I hide TouchWiz and make it appear more stock? It is really a shame Google stopped the GPEs
I'm using Nova Prime on my Note 4 running the new 5.0.1 TW. It's better than before but it's still TouchWiz.
would you say it is a much better improvement though?? Less bloat ware and useless Samsung apps right?
The only difference I noticed with the bloat is that you can now disable Evernote if you don't use it. On 4.4 you couldn't.
