recently when i joined my android to my windows vista for mass storage(i have usb debugging mode always on as i always do mass storage) i was prompted to a box saying "do you want to scan and fix removable disk (G
/(h
". i at first ignored and cancelled it few times but it kept on coming so i decided lets fix it anyway and checked "scan and fix" but then windows says "windows cant check the disk while its still in use"...now what to do??
i later unchecked scan and fix option and checked recover and repair option and it did work and i was able to use go through my files in android...but again when i joined the box pops up again every time
although i am able to see my files but i have noticed that all my folder's have turned into(work as) application(?????), earlier i used to just copy-paste them, as my backup, into my PC but now i cant(since now they are now folders turned application)...where am i lacking guys, what am i supposed to do??
all i want is smooth mass storage and no sticky situation
/(h
