School me on ROMs?
uRabbit
I am trying to use SNESDroid (free) to play some old SNES games.
Terminology:
I know what (U) and other country codes are, but what are the others? h1c, h2c, (!), etc.?
States:
How do I save a game, load it, etc.? I clicked save or load state and nothing happens. There is also select state. No clue.
Thanks!
(!) is the most important, it means verified good dump. Stick to these and you will be fine. If your curious for the rest of the codes, see https://docs.google.com/View?docid=ddmjzkpg_2cgv2ddfg
For the saving, you can either do a normal in game save if the game supported that originally, or you can do a save state. This lets you save in games that didn't originally support it. The slot is where you want to save the file too.
For example in snesoid (what I use, but probably similar in your app), you would start the game.When you want to save, you hit menu then save and pick the slot. If you want to load it later, you would hit load and pick the same slot.
