Root Screen brightness
Yoinx
Android Expert
So lately my screen sends insanely bright even at the lowest level.
Anyone know a way to tweak this without using something like lux?
Sent from my VS920 4G
Which rom are you using? If it's a stock rom, then it's a known thing. I'm going to try and learn how to adjust minimum brightness at the kernel level but it will take a while.
Good I could use that, but there is one app that can kind of lower your minimum even lower its called screen filter but its kind of "fake" you'll know once you use it
