Help screen color please help
That depends on what caused it. Bad driver on the motherboard? Bad cable? Bad display? You can't fix symptoms, only defects. What you're giving us is the symptom of some problem.
This is the only symptoms that I have. It was working fine yesterday, today the colors are off. All I did was turn it off for the night.
