Screen comes on when battery is lower than 13%
it stays on for 20 seconds, then screen turns off (i set the screen to shut down after 20 seconds)....
i do have power saver....but i cant imagine this is saving power!
The screen is probably turning on to let you know power saver is active. Try turning it off, then see if it does it.
I have a couple of phones which did that.
