D
Deleted User
Guest
This is now my second device from Rogers and I have the exact same issue as before. When I turn the screen on, at times it shows up discoloured (attached images) and the only way to get it back to normal state is to restart the phone.
Has anyone else experienced this and if so, do you know if there is a way to fix this through a software update? or would this more likely be a hardware issue?
