Help Screen Discolouration
thicks56
Hi,
had my One X for a month and a half now and love the phone,
Notice a few days ago when i loaded up google there is a small circle right in the bottom corner of the screen the white is showing up as a slightly yellow colour.
when i first got the phone noticed that the screen in this corner made a slight clicking noise as though it didnt quite fit properly so i assume its something related to that,
The circle is only about 3mm round and not really noticeable unless you load a page that is white so i may just have to bite the bullet and put up with it.
Not sure what to do to be honest, any advice welcome :-)
Take it back to where you got it.
Had the same issue with my One X, but it was along the top of the screen.
Bought mine through Phones4u. Had a bit of a faff getting it changed as i bought it online and the guy in the shop couldn't replace it. They sent a freepost bag out for me to return it and had the replacement a couple of days later.
I say return it. It took 3 devices before I got one that did not have screen issues. With that being said I think they need better quality control with these phones.
Thanks for the advice guys,
I have spoken to the guys at the carphone warehouse that i got it from,
Unfortunatly i am outside of the 31 day time for getting an instant handset replacement,
I have been told to take it to another store with a technical advisor that might be able to help and if he cant sort it then is should apparently be covered under warrenty for sending off to be fixed.
But not sure how long this will leave me without a phone for.
I got mine 7 days ago and noticed same thing at top right of screen. Replacement coming tomorrow - mainly because the SIM card is intermittent. Message keeps poping up saying no card or asking for PIN again.
I got a replacement phone several days ago. There isn't a yellow spot on the screen and the sim card is nolonger intermittent. I'm happy :)
Hello!
New to this.
I've just sent my phone back to three with two 3mm circles of discolouration.
Received an infuriating letter back claiming the fault is caused by water damage and are refusing to replace. Of course to me this seems madness as it is clearly a screen fault. Does anybody have a report of the problem and how it is caused that I can counter the arguement with?
Also has anyone sent back to HTC directly and had a replacement. If so who should I contact.
Please help!
