I recently dropped my phone and smashed the Digitiser. It's 3 years old, it's the original Desire G7 A8181.
After dropping it all was well, other than the smashed digitiser.
I decided to replace the digitiser as the phone was fine other than this.
I received the digitiser and followed a guide to installing the new one, All seemed fine, as far as I was aware I was very careful to take it appart properly and put it together, I even inspected parts as I went to be sure I didn't break anything.
I put the phone back together with the new digitiser in place and turned the phone on for the AMOLED screen to not respond whatsoever. Doesn't even light up. I looked closely and could see a line swooping across the AMOLED screen and assumed it was a crack.
I assumed that at some point when installing the new screen I had bent and cracked the screen
SO I ordered a new screen.
It arived today, I put it together, installed it as correctly as I could and voila, nothing.
Screen is still black, no response however the digitiser works and so do all the buttons because I can answer calls by swiping down when it rings..
Any ideas? Or anyone know where to start diagnosing the problem? I'm dieing without this phone at the moment.....
Cheers!
Cheers!
