Help! My wife and I both have Epic 4Gs. Mine still runs fine, butin the past 24 hours my wife's phone's screen has started to fail. It started with a loss of colot that made everything seem dim and red-tinted. And it's getting darker by the hour.
So the main concern right now is how I can back up her most important data (pictures, contacts, calendar). Now, I know how to get the photos off the SD by just hooking up with the USB cable to the PC. But I don't know how I can get the contacts or calendar off there. Is there software I could use?
Part of the problem is that with my phone, I put everything on the Google Contacts and Google Calendar and sync all day; while my wife uses the standalone android Calendar and Contacts on the phone. So some of her data only exists on the phone.
Assuming it dies before we can download the data ourselves, can the Sprint store staff get the data off without being able to use the phone's screen?
Any tips (other than, "Gee, you should have backed up periodically before") would be greatly appreciated. Thanks!
