Help Screen Flashes for a split second then won't work at all.
godsdead
The GSM Galaxy Nexus is basically brand new, I use screen protection and a protective rubber case, it is not rooted and running stock android 4.0.2.
The GSM Galaxy Nexus has no damage or scratches at all.
The problem im having is the screen will not display anything, But the phone is still working in the background, and responding to touches, even though Nothing at all is being displayed.
I have tried, removing the battery, holding down the power & volume buttons simultaneously, power in, power out, trying to boot the phone without the battery.
The only signs I can see is a split second of what should be shown on the screen, for instance when turned off and in the power source, when I hit the unlock button, I get about a 1/4 of a second of the battery graphic show up.
The last app used was the camera app, and the phone has been stuck in this state since.
From these signs, it looks horribly like a hardware failure, Im lost on what to do, I really need some help from you guys!
Thanks in advance.
