Strife21
Member
I am having an issue with my brand new thunderbolt. Sometimes when its plugged in and charging the screen will eventually start to lag out. I can literally swipe like 3 times and screen wont move onto the next.
Also even on screen button presses become delayed. As soon as I remove the device from the charger the issue goes away. I am using the AC adapter charger and usb cable that came with the phone.
I took it to verizon today and explained my issue to tech support and his reply was that I should try not to use the phone while its charging.
He then took the phone in the back and claimed he couldn't replicate the problem so there is nothing he could do.
I have tried a battery pull which seemed to fix the problem for a while but then it eventually started happening again. I then factory reset the phone and still had the same issues. Has anyone ever heard of something like this?
