Screen Lock after update
did a search and couldnt find anything so sorry if this has been answered before. since the update my screen lock is the slide from left to right like an iphone whereas my old one was the arc from top right to bottm left(which could be flipped from side to side). the new slide unlock thing is great if you're right-handed but i'm not so its difficult and unnatural to unlock the screen one-handed.
is there a way i can change it, upgrade it, downgrade it or even an app that i can use without having to modify the squiggly lock pattern? i dont want security lock out, just a simple screen lock like the old one. i've been thru google and the market looking for options but cant find anything for the X10.
thanks in advance
not sure if this will help but try settings>location and security>screen unlock, mine says set up screen lock. in that option there is a bit that says pattern(draw pattern to unlock screen). dont know if you know it but even with the horizontal slide if you touch the corner then swipe up in the arc that we used to have then it still works, as long as you touch the corner first) hope some of this is of use to you as im just home off night shift so im tired and maybe not thinking straight lol
lol
