Screen lock in car dock
gthomas719
I don't see this issue covered so I'll ask it. Apologize if someone has already mentioned it.
When I put the Droid into the car dock, it automatically converts to the car home screen like it is supposed to, but nothing works unless I plug in the car charger...:eek: I can push the screen and buttons till I'm blue in the finger but nothing will work while not plugged in. The second I plug it in, it work perfect. Anyone else have this issue? Is it a setting I somehow accidentally set? Should I restore it or take it back?:confused:
+1
Not having that issue, but I do find it annoying that the screen sleep mode isn't independently adjustable.
Also, I find it downright insanely bad design that you cannot press the screen lock button while it is in the car dock.
I think they have some work to do with "car mode".
