Screen Lock - Pin/None
Hello,
Does anyone know of a widget that allows you to conveniently switch between a pin secured screen lock and a screen lock without pin security.
Basically, when I'm out and about I like to have my phone pin protected, but when I'm at home/work I'd rather be able to unlock the phone without the trouble of typing a 4 digit pin every time - which is many times an hour.
At the moment I have to undertake the arduous task of going into the settings menu and enabling/disabling the pin. A simple home screen button would make things much simpler.
No Lock Screen looks like what you want.
I use a lock (not security lock) bypass app (screenmodewidget) so just turn that off when I want my phone to actually lock. When that, and presumably others like it, is on I don't have to swipe to answer/wake the phone but it won't allow it to go into pin/pattern lock either. I just toggle it off and pin/pattern lock kicks in.
