Hi,
This question relates to my HTC Desire.
I have spent the last few days seraching and downloading and trying apps, but have not yet found one that does what I want.
I want an app that will allow me to lock the screen (by tapping on the app shortcut on home screen), the screen can then ONLY be unlocked using a password/passcode/slide or similar control (i.e. unlikely to be unlocked in your pocket) and where the screen will NOT switch off - therefore not requiring the use of the power button to turn it back on.
Preferably, the screen would dim after a pre-determined time to save on battery power, maybe even dimming to black (off, but without having to use power on to switch back on).
I have tried numerous apps including Screen Off, No Lock, Screen Off and Lock, Lock Screen Widget and most recently WidgetLocker.
None of these (as far as I can see), do what I want.
WidgetLocker appeared to come closest, but still the screen timeouts and switches off requiring the power button to turn it back on. Also, it defaults to 'Tool mode' which then necessitates another tap to action 'Lock mode'. Also, when in 'Lock mode', if the notification bar is dragged down, this then activates the screen and hard buttons.
I have tried using Keepscreen to avoid the screen timeout function, but this only works when other applications are running.
Any one know of something that fits my fairly specific requirements.
