Help Screen locking up while in use
xsandraaa
My Motorola Droid 2 has been locking it's screen up WHILE I'm using it. I'm not sure if it's an app i'm using, but it's been bugging me. Every two seconds, WHILE ITS IN USE keeps locking itself up, I have to keep turning it off and on.
Go to settings, Display, Screen timeout and check that you don't have a ridiculously low setting. The lowest should be something like 15 seconds, and believe me, that's not very long when you're using it.
If that doesn't work, then try a battery pull and see if that fixes the problem.
