screen not working properly
tdholland
Ok soMy android phone's screen isn't working properly... its kind of like it has a mind of its own... how do I fix this? why is it doing this? any advice would be great. Since I do not currently have insurance on my phone.
Welcome aboard. I'm not sure if the device is defective, or the problem is caused be a rogue installed application. Your best bet (in your case) would be to uninstall all the apps that you rarely used.
Also, check inside your device's area of support for some assistance from other members. You can select your device model from the list on the home-page.
Best of luck. :)
