Hi,
Welcome to the site!
I am working with very little information here, so I could be barking up the wrong tree.
I guess that you have some anti virus and/or security tool installed and it is giving you this warning. In which case you may have installed an application that is generating a screen overlay and provoking the message.
A general rule would be to check any apps that you recently installed (or automatically updated) to see if one of those is the culprit. This list you will get from the recent tab in the play store. Just deinstall or disable apps from that list until the problem disappear.
Regards,
Eric.
