Help Screen Resolution lower than normal!
srlee762
My glass randomly cracked in my pocket the other day. More like a pin point shatter (like a small bullet hole). With that though the screen resolution went down. I can now see the pixels very well (almost looks like it's running at 800 x 480).
My question is what caused this and is there any way to fix it (settings or other wise) or is the screen itself busted?
Everything else works fine. I replaced the glass on the screen and did a factory reset (thinking it might be a software issue) and it's still at low resolution.
Has this happened to anyone else? Tried doing a search and literally nothing came up for me.
Thanks in advance!
Srlee
What ever broke the screen could have damaged the digitizer. Don't know of any software fix for hardware problems.
