Help Screen Rotation Slow
ARR22
Hello Guys Sorry if this has been asked. I have already enabled dev options and set animations, transitions etc off. And have made sure smart stay is off. But my screen rotation still lags alot. Im talking about 2-3 sec bad. Its brand new I just upgraded from the Note 3. On the note 3 I had a option to turn off Smart Rotation. But that does not seem to be available in the Note 4. Does anybody know of a way to speed it up. Its annoying waiting for it to rotate especially when you have to send a quick email or message. I am using Apex launcher but I dont think its the culprit as it lags in touch whizz as well. Thanks in advance.
Do you have an SD card? If so try removing it and see if that helps. Also make sure your screen mode is set to Adaptive to test.
Good Luck!
Ron
