Help Screen rotation
max0603
Does anybody else have trouble rotating their screen on 4.1.2? Seems to work for a little while then stops. Any solution people?
There are a few solutions. Some people use a 3rd party rotation app. I just go to the stock phone app and select the dial pad screen. It will rotate once you are in the dial pad. Once in a while, it will still stuck even after I rotate it a few times in the dial pad screen, then I will have to go into the Movie Viewer app and rotate it a few times. Of course you could also restart you phone and it will for sure fix it... for a while. :p I can't believe they have not pushed out a fix for it yet when so many people have this problem. It is a shame.
