girolez Often Off Piste Nov 28, 2013 #2 Hi There is no screen saver as such. If you want to stop the screen going off you can set the delay to 10 mins max in Menu Settings Screen Or keep it on all the time when charging in Menu Settings Developer options If you are referring to the lock screen you can set it to none so long as you are not using an app that requires the security Menu Settings Lockscreen Hope this helps Roger
