screen savers
Hello and welcome to the forums - thanks for joining :)
When you say screen savers, do you mean like on a PC or do you mean a live wallpaper (background) for your device?
hi
how to download screen savers
Hello and welcome to Android Forums. I'm guessing you're talking about "wallpapers" - this can be done a few ways. 1.) Long press on the pic and you will see an option to "save" as wallpaper. 2.) Depending on the device you have, there should be a feature that will give you that option inside your gallery or wallpaper applications. 3.) Here is an application that you can use to assign a pic as your wallpaper.
I hope this helps. :)
