Screen shots, etc?
PrinceCorwin
Android Expert
Just got the RAZR HD. Is there a built in function to take screen shots?
Also, what about the quick settings for wifi, airplane mode, volume, etc, I'm used to seeing on other phones when I pull down the notification shade?
One more... Is there a way to make the battery icon show a numerical percentage?
Thanks ahead of time for your help.
Sent from my DROID RAZR HD using Tapatalk 2
Screen shots - Hold Power Button and Volume Down until screen shot is taken.
I use Nova so I don't exactly recall but I think if you swipe left from the home page, you will see all the settings you are after. I use the power control widget for most of those settings and hold the power button for the pop=up to go into airplane mode.
I use a widget for battery percentage and don't think you can show percentage with the stock software.
echo Batwings - power/volume down for screenshot. swipe left from home screen to get quick settings for wifi, bt, gps, mobile data, airplane mode. you'll need an app for numerical battery reading.
