Screen shots on SD Card?
gloriousnumber1
Android Expert
Anytime I cake a screen shot, it saves it on the internal phone memory, and not the SD card. Anytime I replace my phone or factory reset, if I want to keep them I have to back them up.
If I make a folder called "screenshots" or such on my card, can I get my phone to automatically save them there instead?
Hello glorious. I'm not sure of the Razr Maxx folder hierarchy, but I place (drag) screenies and other data from internal memory onto my 32Gb sd card via PC.
I made a folder, but it's just, "PicsFromMem" and is standalone, not in the DCIM etc.
That all makes sense. Really what I want to do is make them save to the SD card by default, like every other picture I take does.
Try to change where the screenshots are saved and manage Internal Storage" option under Settings -> Storage option may work. But you just have to thell it to move them every so often.
