Screen Size and CPU's
ZingXao
What screen size would you say is best between a 3.7" screen and a 4" screen? Is there a big difference?
And regarding processors. I can't afford a dual core, and am back contemplating between the Incredible S and Galaxy W.
I was all set on the HTC, until I noticed that the Samsung has a 1.4GHz CPU. The Incredible S uses a 1GHz CPU. So, would there be a NOTICEABLE difference in the long run? That's the only thing that's putting the Galaxy W in the back of my mind... that and the price.
Anything 1Ghz or above is great, and well the .4Ghz does make a difference in loading times. However whats more important IMO to check is the RAM for the ability to have more tasks running simultaneously. Not sure how much either device have.
As for screen size, I'd prefer a 4incher. I tried handling my friend's Desire S when he asked me to set up internet, and it just felt a little bit too small for me.
Screen size.. Bigger is better.
What really makes the difference is overall phone size.
Cpu speed can be overclocked.. If you root it
