Screen timeout affects net connection
While downloading , i notice that net connection goes after screen timeout.(max screen time out =10 min)
If i am downloading big file which needs more than 10 min, I have to touch the screen to keep it active.
Its not possible to sit and monitor all the time, any solution.
Model: Samsung galaxy S
Point still stands. You won't manage to fix whatever it is as long as you have a battery booster app because that's how they boost your battery, by disconnecting you once the screen turns off. You can try reading their description at the play store: "boosts your battery by disconnecting you from the internet once the phone display is turned off".
As for it happening before installing the app, you're probably in power saving mode. Which is essentially the same thing. But even if you disable power saving, you will still disconnect because of the power saver app.
