So here is the story basically. This is technically my third droid. The first one had something wrong with the screen where it wouldn't do anything I wanted. For instance...if I tried to press any of the keys on the right side of the screen, they wouldn't respond. Whatever...got the phone replaced in-store. Second phone comes, the slide is VERY loose. The screen actually had about a millimeter and a half on the left side of the screen that it would give when pressed. It made a very loud tap sound when pushed. OK, called Verizon tech support, they send me a DROID 2. I'm thinking SWEET. Not really... Not even 4 days into owning the thing, the screen randomly shuts off and won't come back on without a battery pull, sometimes 2 battery pulls. Over the past few days this has happened multiple times, each more frustrating than the last. I'm getting irritated with mototola. I just called Verizon and they are sending out yet another device. I'm getting annoyed with this whole thing. I shouldn't have to call tech support every other week it seems. Does anyone have a fix for this problem? I've done a factory reset, among other things. I have my old 16gb card from my D1 in there...could that do it? If anyone has had this problem and found a fix for it let me know. I also have the Verizon extended battery..could that be doing it? Please...any help would be appreciated. I'm rooted if that helps at all.
