screen wont on
sometimes my phone just go off on it`s own, and sometimes the screen won`t wake from sleep when i press the power or home buttom lights go on(Phone is rooted)
There are many possible explanations, unfortunately. If this happened at a particular time, e.g. after a call, then it would give us some clues.
What phone is it? Apart from rooting have you made any other modifications to the phone software? Did the problem start after you rooted, and if so was that straight away or later? Have you tried anything to fix it? Have you tried to update the software since it was rooted (not a good idea unless you return to stock first)? Have you checked that the proximity/light sensor isn't covered by dirt or a case?
Sorry, no answers because we'll need more information to identify the cause. Those are just a few questions that occurred to me.
The phone is funker r504, and there is no update(officially) and i think the problems started after rooting
Can you get the original firmware to return it to stock (the cleanest way of unrooting is to reload the stock firmware completely, overwriting any modifications)? If that fixes it then we know that was the problem.
I'm afraid I've never even heard of this manufacturer, so have no idea where to find the firmware unless they make it available for download themselves.
There is a firmware at FUNKERTECH.COM but i cant flash it(brcm base firmware)
