Help Screen Won't Timeout After Missed Call
NativeTxn
So I had noticed that periodically, the screen on my Galaxy S3 (AT&T) would stay on and wouldn't timeout properly. My "lock screen" is set with no password, pattern, or otherwise (simply swipe to unlock). I have the phone set for the menu buttons to turn off after 6 seconds and the screen to turn off after 30 seconds. However, it would be fine for a while and then all of a sudden stop turning off and just stay on until I pushed the power button to turn the screen off. I turned off Smart Stay and have been through multiple menu options "resetting" them, etc.
I searched online and found others who had the same/similar problem. It seems as if I have narrowed it down to the fact that it happens after I have a missed call. I have tried replicating this and the only time I can replicate the problem is if I call the phone so that I "missed" the call, and even though it was working perfectly prior to the missed call, after the missed call the screen starts staying on until I manually turn it off.
Resetting the phone (both using the power button or pulling the battery) resolves the problem, but only until there is another missed call.
I've run searches both using Google and through Android Forums, but have yet to see any solution other than resetting the phone and hope you don't miss a call.
Has anyone else run into this problem? And if so, has anyone else found a solution? It seems ridiculous that I would have to restart the phone every time I get a missed call just to ensure that the screen turns off as it should.
I'm stock, running APEX Launcher on JB 4.1.1 (I747UCDLK3). I was hoping that this might be resolved with the rumored firmware update, but as of now, I'm told my software is up to date so the problem remains.
